suggestions for cheap meadia. I had the best success with maxell DVD+R. But would like to go with something cheaper. I have heard rumor that some dvd media advertise 1X but support 2X. Success stories using cheap DVD's wanted please! Users of the sony external drive are of particular interest. Thanks
i have used optodisc blue and silver with very minimal problems. 2 failures that were software related not media related out of 150 discs. paid 90.00 for 100 dvd-r. hope this helps
BestBuy has Memorex DVD-R and DVD+R as a 50 pack for $99 but I am not sure about the quality of them. You might want to do a little research
Ritek 1X upgradable to 2X DVD-ROriginally Posted by Cmonteith
- 1X for most dvd-r burners.
- 2X for Sony DRU-500A(E) firmware 1.0f only.
- 2X for Pioneer 104-A04 firmware 1.31 only.
These are the cheap medias (Quality range - good => least)
AllMediaOutlet DVD-R
Lead Data DVD-R
- AllMediaOutlet & Lead Data DVD-R are in same level.
Princo DVD-R
Check out their comparability list http://www.allmediaoutlet.com/drivechart.html -
Sony DRU-500A(E) is older model, DRU-500ulx is this newer model so it works with your model plus compability to more media. good luck!
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 18:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 13:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 17:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00
