    Portland OR/Hita Japan
    I have tried many times to get a .sub off of my dvd so i can edit it.
    But every time mencoder screws up. Any way to fix?
    heres my terminal input:
    mencoder -dvd 1 -ocv xvid -oac mp3lame -vobsubout subs -vobsuboutindex 0 -sid 1
    it just quits.
    help.
    Q
    "Good Luck 007"
    In Memory of Desmond Llewelyn
    Feb 2003
    Bloomington-Normal
    if that is the exact command you use, then it would quit....
    your flag to use xvid and the video codec is wrong.
    you told it -ocv
    when in fact it would be
    -ovc
    Feb 2003
    Bloomington-Normal
    Wouldnt you also wish to specify an output file by using the flag:
    -o /path/to/output
    not sure about that one though...
    Hope this helps.
    OK
    With some tweaking to FFmpegX output, I got the .sub file off.
    Now when I try to import it to title lab, it shows no text, and just 000000's across the timeline.
    Anyone kno what to do?
    Q
    "Good Luck 007"
