How can I convert a dual avi divx file to VCD but selecting only one language from both?
With TMPGENC or any other tool?
MUCHAS GRACIAS A TODOS.
8) :P
You'll need to join your AVI's using VirtualDub. Extract your audio, and encode using the encoder of your choice.
If the audio in these AVI's is AC3, then you should also run AC3FIX.EXE on them, to repair any corrupted frames. If you do not, audio sync problems will appear in your end result.Impossible to see the future is. The Dark Side clouds everything...
Converting from PAl to NTSC and changing language
By BaldBill in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2009, 22:43 -
Dual Language Films
By Witchypoo in forum Newbie / General discussionsReplies: 6Last Post: 29th Jun 2008, 06:42 -
Converting Dual Layer DVD to Divx/Xvid
By Snorph in forum DVD RippingReplies: 8Last Post: 15th Mar 2008, 17:37 -
Converting from DVD to PSP with SUPER, wrong language
By supraman215 in forum DVD RippingReplies: 2Last Post: 12th Dec 2007, 10:50 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 14:53
8) :P
