I've been trying to use the 16x9 video format on a 4:3 disk. The video is mastered in 16x9 (in the info window it reads a 16x9 720x480). I have the video clip marked as 16x9 widescreen in the program. Now when it is burned the menu and the video are being displayed slightly off the screen. I've done this a few times and I can't get what I'm doing wrong.
Would someone please tell me how to create a sucessful 16x9 video on a 4:3 disk in Dvd Studio Pro from scratch, in detail.
A quick answer will not help.
with the 16:9 track selected go to your prop inspector, video section, choose 16:9 letterboxed.
when you build the disc and what on your mac is it widescreen? if yes but not on your set top dvd player then you might need to change the settings on your player to 4:3 letterbox if your tv is 4:3 or 16:9 if your tv is widescreen.pants on, pants off, pants the floor. -
It is!
My tv is 4:3.
PLease just tell me step by step on how to create a dvd in the 16x9 widescreen format for a 4:3 TV. I been tweking thing little by liitte. with little or no change. At this time I think a walk though is best.
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 04:08 -
DVD STUDIO PRO 4 problems
By macuser1960 in forum MacReplies: 9Last Post: 14th Mar 2009, 04:44 -
DVD Studio Pro
By macuser1960 in forum MacReplies: 3Last Post: 12th Mar 2009, 07:45
