I know this is the most basic of questions, but I didn't see it in the FAQ so I will ask anyway: I am burning MPEG's on CD-Rs using Roxio easy cd creator 5. Is this a VCD? Or do I need the information in MPEG-2? And are there MPEG to MPEG converters? Thanks for any comments.
Actually, the guide says MPEG 1 is what I want and I think that is what I am burning (it says MPEG). So would this mean the program I am using (adaptec 5) is at fault? Or do I have to prep the file with a specific type of program? Thanks for any comments.
It says MPG on your harddrive, but DAT on the disk. A DAT is an MPG with a little more information tacked onto the beginning. Roxio is very vague, and doesn't actually tell you if it's VCD/SVCD/DVD. Get Nero, you'll be happier. I suspect it reads the MPG information and burns accordingly (hope you encoded to standard)
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 16:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 09:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23
