I used Smartripper to rip fiels from dvd using the proper steps, etc. I can open it up and watch it and everything...but when I go to load it into DVDit! PE, its telling me "Dvdit cannot use this file..it appears to be an mpeg, but is not identifiable as ntsc or pal" has ANYONE had this problem ro have any solutions?...everyone I asked hasnt heard
You need to use elementary streams. I suggest reading the manual under the area of Preparing your Source Assets
If oyu have the vobs on your drive, you can use VobEdit to demux them, or even TMPG to demultiplex (but it won't joine multiple cells), so I'd recommend VobEdit. If it's not in the TOOLS here, it's in the download section of doom9.org
If you're looking to do a straight copy of the disc, try using this method for an ISO copy https://www.videohelp.com/forum/userguides/141024.php~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Idid elementary stream processing and I have m1v and wav files on my comp now...any clues?
Load those into DVDit, and I suggest finding out how to encode you wav to ac3 with dvdit pe because that is what your paying most of your money for with that program.
actually...Im sorry I meant m1v/ac3. But the problem isnt with the audio anyways...as you see in my first topic..when I load the VIDEO part it gives me the error I mentioned
Odd Recording Volume Problem
By blewyn in forum AudioReplies: 5Last Post: 10th Feb 2013, 13:27 -
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 01:07 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 12:22 -
odd frame rate problem
By deadrats in forum Video ConversionReplies: 0Last Post: 7th Dec 2008, 14:32 -
Odd problem? dv video disappears
By phorkster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 17th Sep 2008, 07:57
