I have searched and have not found a clean definition of gop setting. I see a lot of refrences to I's, P & B setting. But my card only has number settings. 1-15 for GOP & 1-5 for Sub GOP.
Is there some sort of refrence chart.
Having a lot of pixlation a scene changes. I've read that this is do to a poor GOP setting.
Don't give in to DVD2ONE, that leads to the dark side.
If yoy are making DVDs then there are typical GOP sizes. Making GOPs shorter keeps more reference (I) frames which can reduce distortion but the filesize will be bigger. See the glossary for a bit more info
Panasonic DMR-ES45VS, keep those discs a burnin' -
Read the glossary.
I don't see the answer to my question.
Where do I need to set my GOP to avoid pixlation at scene changes?Don't give in to DVD2ONE, that leads to the dark side. -
Let's see.
Tried
Gop set at 5
Sub gop set at 3
Gop set at 4
Sub gop set at 2
Gop set at 1
Sub gop set at 1
Still not it.Don't give in to DVD2ONE, that leads to the dark side.
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 16:29 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 13:19 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14 -
ES Video and GOP timecode
By arturo83 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2007, 07:57 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 9th Jun 2007, 00:08
