Results 1 to 10 of 10
  1. How do you burn cue/bin files to a cd-r?
    I have two bin files and two cue files, I suppose there should be one bin and one cue file in each cd.. I use cdr-win burning program.. how do I burn it to work on my dvdplayer?
  2. You can also try FireBurner
    http://www.fireburner.com
    or BlindWrite Suite
    http://www.blindwrite.com
    they can both accept Cue/Bin images, and unlike CDRWin, they can also write on 80min and larger sized CDR's without problems.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Alltså, den ena cdn skall ha den första cdns cue och bin filer. Men de är tillsammans 746 mb, hur kan de få plats på en cd?
    den andra cdns cue/bin filer är 627 mb stor
  4. oops, let me put that in english, I forgot..
    the cue/bin files of cd1 are 783mb large. How is it possible to write it on a 80 min or 74 min cd?
    Is it possible to write 80 min cd on cdr-win program?
  5. I've had no problems writing to 80min discs with CDRwin. Never tried anything larger (never even seen a >80min disc).
    Darryl
    www.fireburner.com
    or BlindWrite Suite
    www.blindwrite.com
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  6. Is it just to load the cuefile with fireburner and then burn??
  7. Yup, just load the Cue file and Burn!
    and CDRWin does not support anything larger then 80min, I know, cause I have 90min CDR's
    Best Regards,
    Sefy Levy,
  8. sefy, I can't talk to u on icq?
    why are you offline?
  9. I'm invisible, i've been getting threats (like all my friends from Israel) from Arabs, so I'm on invisiblity, just message me and i'll reply.
    Best Regards,
    Sefy Levy,
