Using the instructions from the link below:
https://www.videohelp.com/forum/viewtopic.php?t=150179
I made a back up, in widescreen, BUT when I back it up, It ended up being full screen, and everything is cut off.
Any Suggestions on how to maintain the wide screen.
That link has instructions for all sorts of things: Sizzle, Minx, etc. Tell us what programs you followed.
For starters, can you look at your first-generation ripped video file (.m2v or .vob) in Quicktime? Use the QT "Info" box to check the dimensions of the video. What is it? -
I used the following programs
[1] OSeX
[2] Sizzle
[3] Toast
I followed every step from the link on my first post.
meatball -
Suggest you try method posted by WIZEMAN on DVD backup, i find it to work nicely. Likewise, with widescreen formats.
He uses essentially what you used. Ive tried his way and it worked for me
Forgot to put the link in there for you
https://www.videohelp.com/forum/viewtopic.php?t=151644
WOO HOO! this is my 100th post!
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 14:41 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 21:36 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 19:04
