Im converting this Lord of the ring Avi into VCD,and its taking me about 7-8 hours for each hour!
i have a AMD 950 with 756 RAM, its not the best,but its pretty decent.
One of my friend can convert a whole movie in like 2-3 hours...and this LOTR movie is gonna take me like 24 hours.
I use the standart setting,and the motion search Precision is set at normal.
I'm using TMPGenc by the way.Also i use avi2wav to extract the sound first(if that does matter).
Also there is 1 wierd thing...its been a pretty long time i didnt made VCD,but i remember back when i was encoding a lot,when encoding avi into Mpeg,the Mpeg always got about 130% the size of the AVI.
Now lately i been encoding,and i always get an mpeg file that is smaller than the original AVI.Also the quality is still pretty good even if its smaller.
I'm not whinning about this,its just great,but i just want to know why its smaller
thx in advance
oh..and forgot 1 question.
I use nero for burning,and i would like to know if its safe to overburn.
Im scared that overburnning could cause problem to my cd-burner. -
Very odd? I encode VCD's at something like 200 fps on an Athlon 2400+, so you should be doing at least 80 fps ( 1 hour to encode the whole thing ). I strongly suspect the problem is in your resizeing. Since your original is what??? 640x2?? and your going to 320x240? This is very difficult to do correctly and not get a very very skinny picture.
You may get much better speed by cropping/resizeing/masking with VDUB and frameserving?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
original Avi is 320x240 so i keep the same size.
Im not sure i understand that thing about Vdub.Some ppl told me to use the frame serving thing but i dont know how to.
can u explain to me how Vdub can make me converting faster?or if its too long,can u just tell me where i can get the appropriate info?
dvd flick is too slow need faster convertor
By Illusionist in forum Authoring (DVD)Replies: 15Last Post: 19th Feb 2012, 08:16 -
Using AutoGK to convert from VOB->AVI results in slow-motion video
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2012, 13:49 -
Advice on DVIX/Avi dvd players
By aelfheah in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2011, 16:48 -
Convert MKV >> AVI : video is slow...
By condorman in forum MacReplies: 3Last Post: 22nd Aug 2009, 05:02 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54
