is it possible to get the films that are recorded on the panny to autorun (ie without the menu),at the moment i copy a film then rip it onto my hd with smartripper and then convert the files with dvd2one and re write the film...viola no menu and it auto runs..the problem is its a waste of a disk as the original still has the menu on..so can i disable the menu option on th e 20...please help
Results 1 to 1 of 1
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 11:06
