Apologies if this is one of those questions asked again and again ( I did search, honest ! )
When I capture Video in Virtual Dub should I be hearing the sound ?
It's actually capturing the sound fine, the audio info moves on the rh side of the screen, and when I play the file back it's all there, clear as day.
but I can't hear it when I capture. Is there a monitor option somewhere ?
Using a Sapphire All in wonder 9000pro and a Hercules fortissimo sound card.
Any suggestions ?
Thanks,
I'm not sure about your capture card but it sounds like a problem I first had with my "AverTV Studio" Card. The card has a plug going from my tuner (sound out) to the LINE-IN jack of my sound card. I followed the following instruction on fixing the problem. Hope it helps.Originally Posted by Peblah
##### From AverMedia #####
If you have already set up your video capture sequence to use audio, but there is STILL no sound in the capture, then most likely you have not successfully configured the LINE-IN jack on your sound card as the proper source for RECORDING, although for PLAYBACK it works normally.
To do this, you need to run Windows Volume Control. Either you can double-click on the little yellow speaker volume icon in the system tray by the clock, or you can find the Volume Control program in the Programs menu under Accessories\Entertainment.
When Volume Control appears, go to Options on the menu, and select Properties.
Now you place a button in the empty checkbox next to RECORDING.
In the list below that says "Show the following volume controls", make sure there is a check in the check box for Line-IN and hit OK.
Now, all of the RECORDING level sliders will appear, and you can now place a check in the SELECT box underneath Line-IN, and NOW you should properly capture audio in your video capture sequences.-Lineber -
Thanks for that L,
I know what you're saying there but my problem is subtly different to the common 'No audio being captured' question that comes up alot.
I *am* capturing Audio through the Line In, it's just that during the capture process itself I'm not hearing any sound. When I play back the capture it's all there, so I guess I should be able to hear it as I capture, non ?
I'm thinking there's some kind of monitor switch somewhere to kick in ? -
Have it now, the Mixer on the Hercules Fortissimo soundcard had the line in volume at zero - audio was being captured OK via the Recording line in, hence that working.
adios,
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45
