Being pretty to backing up DVDs to SVCDs I have come across a couple of tutorials which conflict in the 'Audio' settings.
In one document it tells one to De-Select the 'Dolby Surround Downmix' while the other doc says to leave this selected.
What is correct or when should one use these settings...
Regards
Pete![]()
I suppose it depends on what you're doing with the audio. If you're converting the AC3 to a WAV then you would downmix, where as you wouldn't downmix if you were just extracting the AC3 to convert to WAV using a seperate program. I think that makes sense.
G'Day CloneAD,
Thanks for the reply.
Well.... I guess what I'm doing here is backing up my existing DVD library onto SVCD.
I do this by first using DVD DECRYPTER then DVD2AVI then finish off with TMPGEnc then burn.
So based on this info, what would be the prefered setting ?
Pete
Best quality AUDIO for Youtube - what settings do you use?
By Bansaw in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Sep 2011, 23:12 -
Audio freq response on various DVD speed settings? - HELP!
By will7370 in forum AudioReplies: 2Last Post: 12th Jul 2010, 15:05 -
VirtualDub -> Handbrake m4v, audio settings?
By milltone blabbit in forum AudioReplies: 5Last Post: 30th May 2009, 22:33 -
DVP5990 Best Picture/Audio Settings?
By avkhatri in forum DVD & Blu-ray PlayersReplies: 7Last Post: 18th Feb 2009, 13:47 -
Need Assistance With TDA 3 Audio (and or Audio Settings)
By isamudysan in forum Authoring (DVD)Replies: 0Last Post: 4th Mar 2008, 21:41
