Ok, ive just reformat my computer..so i lost everything. I have to reinstall all that crap. Anyways, I use DVD2AVI to make .d2v and AC3 T01 2_0ch 192Kbps 48KHz and then load it up to TMPGEnc and encoded a movie, it's turn out to have no sound. hmm...
Results 1 to 9 of 9
In DVD2AVI I select "Decode to WAV" this will convert the selected audio track, generally track 1, to a wav file for use in TMPG. I believe TMPG can't do much with an ac3 audio file.
If you are already choosing decode to wav then I'm not sure what else to advise. -
Which version of DVD2AVI are you using? Anyways, i did select Decode to WAV (AC3, LPCM in the audios.
Did you mistakenly set TMPGEnc Stream type not to do the audio or make it a seperate file?
bottom right on the main tmpgenc window, if you set it to video only you'll get no audio or if you set it to ES video+audio you'll get seperate files for video and audio.
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 08:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 12:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 03:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 05:33
