  1. Can some one help me with a dvd decryter problem. I have tried using different software but it still gives me the same problem. Is due to something i'm doing wrong as i've done my rips this way may times and never had a problem
  2. y'know it would help if you would tell us what the problem or error message is..
  3. Hello...
    the two problems that I had in the begining were as follows:
    1. Kept getting region code not set or somthing to that effect.
    Solution: Right click on the DVD writer listed in DVDDecrypter and set the region to where you are i.e. Region 1 = USA/Canada
    2. ISO write would not play in my set top dvd player.
    Solution: Use file output, then write the files back to DVD-R with Prassi as a data disc.
    Hope that helps
