Hi,
I am wondering if there is a simple way to convert a home DVD movie with Linear PCM audio to DV format (without using several different softwares to extract the audio and video and ......)? Is there any software out there which does this convertion? All I am trying to do is to make a NTSC DV from my NTSC home movie (with Linear PCM audio) in order to convert the NTSC DV to PAL DV by Canopus ProCoder (Canopus does not suport vob) and then once again make a PAL moive. Thanks for your help.
I don't know of a VOB to DV converter, but there are a wide range of tools that will allow you to do the steps (albeit more manually). Use DVD2AVI to create your AVI. I've never used DV. I'm assuming it's a selectable codec, much like any other. I don't see why you couldn't select it as your output codec in DVD2AVI. VirtualDub could be used to merge the Video and Audio from DVD2AVI. Someone with more experience with DV should be able to clarify.
Impossible to see the future is. The Dark Side clouds everything... -
Yes you convert an mpeg into DV in vdub mod. You need to install a DV codec (for example the Panasonic DV codec).
You may also want to try this program:
http://icqphone.ru/video2tv/
http://forum.doom9.org/showthread.php?s=9073f8fb4e9095cb3c9311bbb667ef15&threadid=48302
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 13:58 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 13:37 -
converting VOB to DIVX format?
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 1st Oct 2008, 09:53 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Difficulty In Converting .Vob to Any Format & Keeping Widescreen
By RachelArcher in forum DVD RippingReplies: 50Last Post: 10th May 2008, 10:40
