If I capture a show to an uncompressed avi in virtualdub, are there any good filters to use? I have no idea what they do. Is it even better to capture to an uncompressed avi than say mjpeg at 100%? Are there any settings I can change on my computer to make it drop less frames because right now I can't capture above 352x240 and it still drops about 30 frames in 20 minutes. I have a piece of garbage tv wonder ve and a 900mhz duron, 256mb. Any Help to getting better quality in encoding, capturing filters, anytinhg would be appreciated.
uncopmressed is the fastest you can get.
Filters clean up the video. Or let you minipulate it however you want.
The only one you may want to use would be a noise reduction is you need it. Maybe a slight smoother, if you are going to compress it. -
I would definately recommend using noise reduction and smooth ilters to remove some of the noise that captured material creates.
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
Any good VirtualDub filters to remove common VHS color bands?
By rijir2001 in forum Newbie / General discussionsReplies: 1Last Post: 15th Nov 2008, 16:10 -
6.5gig of HD material on a DL
By luketheduke in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2008, 15:53 -
Is anyone making good S-VHS VCR's anymore with digital filters?
By Wile_E in forum Newbie / General discussionsReplies: 3Last Post: 31st Oct 2007, 13:46
