Hey, I Am pretty new in this forrum.
I have at Xvid movie, and I can't seem to get it convertet to a VCD movie. After I have extracted the wav from VirtualDub, and try to convert it in Tmpenc. the audio dont fit. Can anybody tell me what I am doing wrong?
I have converted other movies before, and there have never been so much problems as whit this one.
The xvid have a framerate og 23.976 FPS and a bitrate of 879 kb/s
and the sound is packed in MPEG-1 Layer 3.
Best regard
.. :: |G|E|N|I|E|Z| :: ..
try just using the audio and the video from the SAME file. that works better sometimes.
Bravoxena -
Bravoxena I am not sure that i understand what you mean, "try just using the audio and the video from the SAME file"
I have used the audio file i extracted from the movie "Treasure Planet", and I use the audio file from virtuldub, with tmpenc. but it's out of sync. -
Geniez I d/l Treasure Planet, and passed the avi through tpmenc with no problem. Just use the avi for audio &video like Geniez says
Stille can't get this shitty movie convertet.
I have been wondring, Is there any way 2 convert this dame xvid movies framerate from 23.976 FPS to 25 ore 29 FPS
But "Ironballs" you say that you have DL this movie, ditten you have any problems whit this movie, becurse I have never have so many problems whit a movie like this one.
I also seems to get this warrning "Invalid Pointer Poeration" It have never been a problem before, but what does this mean?
HELP MEEEEE!!!!
| G | E |N | I | E | Z | -
I Done IT
Finaly i have found out to convert this f#%!¤ movie.
I found out that I only have to change some environmental setting in TMPGenc - VFAPI plug-in and set "Directshow media file reader" to be at the top, that solvd my problem.
Hope that this can help others that have the same problem.
| G | E | N | I | E | Z |
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Time sync problems.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 1st Sep 2007, 00:30 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
