I get the following error while extracting audio using virtual dub folowing theinstructions in the guides (audio/full processing mode, audio/no compression, audio conversion/44100Hz) and wanting to save the wav.
''The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format''.
I have extracted and re-encoded quite a number of files succesfully, have not seen this error. I could use your help.
Thank you.
Open the file in Vdub, and look under FILE / FILE INFORMATION
How many channels does it say the audio streams has ?
I am guessing it may be an ac3. Download and install the older DivX 3 ac3 codecs. Search the forum and you should find threads talking of it, or look in the Codecs section, under Tools to the left.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I still get the following error while extracting audio using virtual dub folowing theinstructions in the guides (audio/full processing mode, audio/no compression, audio conversion/44100Hz) and wanting to save the wav.
When looking in Vdub at file information I get the following info:
Sample precision is 0 bit
Compression is unkown (tag 0055)
Channels: 2(stereo)
Sampling Rate 44100 Hz
Hope this helps, thanks in advance.
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting Music from Audio CD
By prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 17:59 -
extracting audio from submenu
By juetenglord in forum Authoring (DVD)Replies: 3Last Post: 18th Feb 2008, 07:29 -
extracting audio and changing it
By usermm in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 14:41 -
Trimming then extracting audio
By chrishallowell in forum EditingReplies: 3Last Post: 2nd Nov 2007, 00:29
