This is the way I have been burning my VCDs for quite some time now and I am wondering if there has been any major advances which would make my task a little bit easier? Any insight would be appriciated.
1) Download bin/cue files.
2) Convert bin files with GNU vcdtoolsX 1.1 using vcdXrip.
3) Convert resulting mpeg/xml file with GNU vcdtools using vcdXbuild.
4) Burn resulting img files with Toast 5.2 using Multimedia CD-Rom XA
Here is what I am wondering. Is there a way to go from the bin/cue files directly to the img files? Is there a way to burn the bin/cue files directly with Toast? Everytime I have tried that I never get a playable VCD.
Thanks.
I was able to burn the .bin files under Toast before and it worked, but skipped a little. So I used Missing Media Burner to burn the .cue file and it worked even better. The last time I made one I Used Missing MPEG Tools to create a .xml file for my mpeg. And burned using MIssing Media Burner. It just seems to work much better than Toast.....
You're probably talking about SVCD's since you mentioned Multi-track XA mode.
There's a certain .iso-file you can use, drop that in Toast's Multi-track XA mode and then drop the .bin-file. Burn. You now have a SVCD with chapters(!).
That's the easiest way.
(Thread will probably be closed if I say something more about the .iso-file, moderators don't want us to say too much) -
I find missing media burner to work nicely for direct .cue/.bin to CD.
(http://www.versiontracker.com/dyn/moreinfo/macosx/16799)
NO coversion needed, just select your .cue linked to the first .bin, burn and watch
repeat for the 2nd .cue linked to the 2nd .bin
and so on for how ever many there are. -
What's wrong with the easy way of dropping the .bin file onto toast in VCD mode?
Always works great for me... -
VCD's yes. SVCD's no. Except with the .iso-file workaround.Originally Posted by ZeroSix
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
