I got some files with a bigger size than 810 MB.When I try to cut them with tmpeg or others I always got ""Illegal Mpeg-Stream"".I think they
are not SVCD conform.
Is there an tools which is able to cut these files to CD size ??.
Greetz + Regards
Warbreed
What version of Tmpgnc were you using? Newer versions work better than some of the older versions for cutting MPEG's.
I've seen that error when using TMPGEnc to try to cut and join some MPEG2 files. Most of mine are non-standard SVCD's (352x240) but I don't know if thats the issue, maybe someone else on the forum has an idea. You might try another MPEG editor, such as Womble.
If you are trying to get them to fit on a CDR one thing you might try is to reprocess the files in TMPGEnc down to a smaller file size. You will lose a little quality but you won't lose any content.
Drak -
How much bigger? I mean you can overburn a little bit. Did you try and burn it and have it fail, or are you just guessing it's too big?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I was under the impression that 800MB was the limit.Originally Posted by Gazorgan
Why no standard for frames per second?
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 31st Jan 2011, 04:18 -
What's the new standard?
By wild4trv30 in forum EditingReplies: 6Last Post: 31st Jan 2010, 11:39 -
Standard DVD in HD
By killerener99 in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2009, 06:14 -
Standard TV warning
By djmobius in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 24th Jul 2008, 07:10 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
