CAN ANY ONE TELL ME WHAT MODE YOU NEED TO RIP A DVD IN TO GET THE AUDIO TS FILE,I RIP IT IN ISO MODE THEN BUST IT OPEN WITH ISO BUSTER AND ITS THERE.. IS THIS THE ONLY WAY.. AS IN FILE MODE YOU CANT SEEM TO GET IT.. I NEED IT AS MY DVD PLAYER WONT PLAY WITHOUT IT.
All other methods within dvd decrypter will only produce a VIDEO_TS by default,i wasn't aware iso mode created an AUDIO_TS,and i have used dvd decrypter in iso mode before,creating an empty AUDIO_TS folder is simple to do in explorer,then add that folder before you write your disc.
Hello...
Try creating an empty audio ts folder and then burn the empty folder and the video ts folder. That's what I did just in case. It seemed to work just fine. The movie that I copied had the folder on the original disk, but it was empty. Check to see if the audo ts folder has anything in it, if not then try creating one. Also have you ever had success or is this your first try. Because it could be the media or speed. I had a few coaster before I figured out what went wrong. My DVD set top didn't like discs burned in dvddecrypter iso format in prassi or dvddecrypter. I extracted all the files with dvddecrypter and the burned them with prassi as a dvd data disc and It played right away.
Hope that helps
Steve -
I agree. Try it with the empty audio_ts folder. Also try investing in a new keyboard. When those caps lock keys start sticking, that is a sure sign that they about to frizz out on you.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
Ripped with DVD Decrypter - No Audio
By ezen in forum DVD RippingReplies: 7Last Post: 22nd Oct 2008, 01:05 -
DVD Decrypter messing up audio
By Cyrus221 in forum Newbie / General discussionsReplies: 4Last Post: 13th Feb 2008, 01:06 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 16:21
