  1. hi,
    been burning vcds and svcds of home movies for play on dvd (apex 660) downstairs.....
    is it possible to play on my computer that i am making them on? i have 2 HP cdrws 8250 and 9510 ...
    i have downloaded cinmasomething....bs player and vci? somthing.. they will play my VCD but not my SVCD
    can anyone help?
    i create my svcds as follows
    1. capture via dazzle
    2. encode from mpg1 to mpg2 using tempgen
    3. burn using nero
    thanks
    Dec 2000
    Some airport, somewhere..
    The only free SVCD player (that I know of) is STHSVCD. WinDVD and PowerDVD also plays SVCD.
    Jul 2001
    The Netherlands
    I use WinDVD (v2.3) for playing VCD and SVCD discs.
    As far as I know PowerDVD does not play SVCD, only VCD.
    That is one of the reasons that I prefer WinDVD over PowerDVD.
    Jul 2001
    Brazil
    You can try ELECARD MPEG2 PLAYER (Mpeg1 and Mpeg2 decoding).
    Dowload it on http://moonlight.co.il
    or http://www.elecard.com. It's a shareware, but no time expires.
    SYSTEM REQUIREMENTS:
    o MMX-enhanced CPU (Intel Pentium MMX, Pentium II,
    Celeron, Pentium III, AMD K6-2, K6-3, Athlon, etc.)
    o Windows 95/98/NT/2000 with DirectShow or Microsoft
    Internet Explorer 4.0+ installed
    o 32 MB RAM
    o Any VGA card
    o 100 KB of free disk space for filter file.
    I hope help you.
