    Jul 2002
    If I burn a single movie onto VCD it's simple...but if I burn several small movies or Music videos, is ther a `nice and easy` way of creating a menu system
  2. Member Treebeard's Avatar
    Aug 2002
    Nero's built in menu maker works just fine for me.
    Jul 2002
    I tried NERO built in menu creator and found it to be poor, it auto selects `thumbnails from the fest few seconds of the clip, not always appropiate
    Hopefully there is something better and also simple
  4. VCDEasy is the absolute ultimate of all the VCD packages you can use to create menus. You can find it at VCDEasy.org and NO I am NOT the author. I just love the package so much that I think it is incredible that it is freeware (shameless plug).
    Anywayz, you can do virtually anthing you can imagine with the software because it allows you to create stills, menus, transition menus ripped from DVDs, all sorts...if you register on their site (it is free too), you can download the latest beta version which allows you to save your work.
    Great app!
    The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002
  5. Member Treebeard's Avatar
    Aug 2002
    You can select any part of the clip to be the thumbnail image with Nero. Yes the default will select the first frame buy that can be changed to whatever frame you want in the video.
    VCDEasy is better at menus , but I just wanted to point out the incorrect statement about nero's menu creation.
