im using the template that allows me to fit an entire movie onto one disc, everything went well up until it finished burning. When it finished burning...it only went so far into the flick, like more than an hour then it just cut out.....my stand alone vcd player just cut out, could it be the disc, the player..the template...when i played the movie in its encoded state the entire thing played..what must i do...holla.....
I use this template all the time.
https://www.videohelp.com/forum/userguides/84759.php
I have never had any problems with it. -
thats the exact same one im using...i wonder what can be different in my method or your method......im using the settings set out in the guide, no differences, what about you
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 06:02 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
