Hi all!
I use ffmpegX to create a divX (using mencoder) an from extracted .vob. I have installed the appropriate font. Can someone be kind enough to explain how I can encode a divX with subtitles?
Thanks for the help.
The easiest way to access ffmpegX's subtitle option is to create a VOB using OSeX -- rip one VOB that contains the video, audio, and subtitle track together. Not a separate subtitle .SPC file.
Load 'er up into ffmpegX. As Paul said, as you're setting your encoding options, pop on over to the AUDIO tab and check the SUBTITLE box. If you've included only one subtitle track in your VOB, then the default track number "0" is correct.
"Sub palette" can be useful in getting the correct colors for your subtitles, but that can still be a challenge. Copy the VTS*.ifo for the titleset of your movie (if your original disk had your movie as the VTS_02_0.VOB set, for example, copy the VTS_02_0.ifo into your directory, and choose that file for the "sub palette."
If the colors come out weird, try it without any file loaded as a subtitle palette, or try one from another disk (I keep a half dozen in a folder and try them all until I get one that isn't green & red....)
In the options tab, make sure that the MPLAYER box is selected, as this is the tool that scrapes the subtitles out of the video.
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
ffmpegX problem - Preview gives me wrong subs
By no-xplode in forum ffmpegX general discussionReplies: 3Last Post: 31st Aug 2010, 15:55 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 17:36 -
mkv (x624 + 5.1 dts + ssa subs) to mp4 (x624 + 2ch aac + burned in subs)
By chameleon789 in forum Video ConversionReplies: 2Last Post: 22nd Jan 2008, 04:01 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 20:29
