Anyone knows how to work with the srt2sup tool?
Everytime i load a .srt file i immidiatly get the message No TimeOFF!!!
Anyone knows what's going wrong here?
You're not the only one with this problem.
Even an srt-file with only one subtitle line gives the error, although there is a time-off in the line.
There seems to be another problem when saving a SUP-file. I tried to insert a line myself and see if I could convert it to a SUP-file.
However when select "Save SUP", nothing is saved.
I mailed the author of SRT2SUP two days ago, mentioning both problems, but I did not get an answer yet ... -
Author of the software released new version a3.03 without the bugs!
SRT file should be in Extended Subrip format (use Subrip to add the coordinates)
Saving of SUP file is also fixed.
Works fine for me now!
more info at: www.shipleys.demon.co.uk -
Hi All,
I have had to move the program to:
www.shipleys.eclipse.co.uk
Regards
Srt2Sup
DVD Subtitles (srt2sup) not working! What to do?
By panderson in forum SubtitleReplies: 3Last Post: 11th Jan 2009, 06:10 -
Is there any tool for me??
By kemcel in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jul 2008, 23:16 -
Srt2Sup - new line within subtitle problem.
By mattstan in forum SubtitleReplies: 3Last Post: 17th Sep 2007, 13:18 -
Which tool ?
By NICEBUD in forum Authoring (DVD)Replies: 7Last Post: 17th Jul 2007, 14:06 -
burning tool?
By yogart in forum Authoring (DVD)Replies: 8Last Post: 25th May 2007, 14:20
