http://www.dvd2svcd.org
HISTORY:
03 apr 2003 version 1.1.3 build 1
- Enhancement: Added support for Canopus ProCoder 1.25.15.0
- Bug Fix: Permanent Subtitles + Canopus ProCoder didn't work. Fixed
- Bug Fix: Fixed various subtle problems when interfacing with ProCoder.
- Bug Fix: External Subtitles not formated properly, could produce an "Access Violation" or a "List index out of bounds" error.
- Change: I've removed the codec check. Itseemed to give some problems, especially with xvid.
- Bug Fix: If using frameselection, the cd sizes selected would not be reduzed to the proper size.
- Enhancement: Support for CCE 2.66 (and maybe 2.67 too). But, if you are using the demoversion you have to use RB's EclCCE (Load EclCCE.exe instead of cctspt.exe). You can download it here: http://forum.doom9.org/showthread.php?s=&threadid=46664 Thanks to RB for this little nifty tool :)
- Enhancement: Support for CCE Templates (sort of). You can select a CCE Template in dvd2svcd, but this is only for settings which isn't already in dvd2svcd. That is, the template will _not_ overwrite the settings already existing in dvd2svcd.
- Enhancement: Chapters are added to the ECL file. Should make the chapter entries when authoring dvd's more precise.
- Enhancement: You can preview External Subs in the Preview Window.
- Enhancement: Added beta support for Avisynth 2.5 (you must do the installing yourself if you want to use 2.5, also you will have to point to the right 2.51 plugins in the frameserver tab)
- Enhancement: You can now encode in MPEG2 but use MPEG1 (VCD) when muxing and authoring. This should help some who can't watch SVCD's only VCD's on their DVD (I know Panasonic can, using this method). All you have to do is go into the bbMPEG tab, dropdown the bbMPEG advanced features and doubleclick on MPEG1.
- Enhancement: The chapters is now saved in a maestro compatible text file, which you can use when dvd authoring. I hope to extend the dvd output options in the next release.
- Beta testers: DDogg, RB and Clixo. Thank you :)
Hi everybody
I take this opportunity to say "thank you" to the creator of dvd2svcd for giving us such a great tool. It works better , faster and the result is of much better quality than all(!) commercial progs I tested, and these were a lot.
With Avisynth2.51 I had no problems until now, the encoding speed is about 50% faster!
Once again my biggest thanks and keep on duing this outstanding work!
Cheers
grommi
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 16:57 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 06:05 -
New PC Build
By faramith in forum ComputerReplies: 37Last Post: 19th Oct 2009, 15:26 -
Watch movies online with other online also at the same time?
By Ghtpua in forum Software PlayingReplies: 5Last Post: 11th Feb 2008, 13:02
