I captured 90 minutes of a tv show from vhs last night, and ninety minutes later, after it finished, I stopped the capture.
I used Virtualdub with the PicVideo MJPEG codec at quality 19, 720 x 576 for eventual dvd output.
Before running through TMPGEnc (I intend to convert to mpeg2 at circa. 5000 VBR) I checked the 30gb file (using Windows Media Player and also the ATI Player) and whilst the first few minutes were fine the majority was just a still of the last frame (the last frame is the BBC logo at the end of the vhs tape).
I skipped to about the 60 minutes in point and it was still the same frame, and at the very end sure enough, the same frame.
Strange thing is, if you look close at the very top of the capture, there is some movement across tehe full width of the screen which I guess is the actual capture. It's far too narrow to accurately determine exactly what it is but there's enough for me to say it is the whole of the 90 minute capture.
I've captured off digital tv many times and done a couple of vhs conversions but never had this problem before.
I was thinking at first it might be copy protection but I have a macrovision scart remover thingy so there can't be any copy protection on it.
Anyone have any thoughts?
Many thanks,
Will
Results 1 to 1 of 1
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
captured footage, now notice a line throughout frame
By Ray S in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2011, 11:38 -
Conversion lasts 1 second... and nothing is converted!
By AlxCap83 in forum ffmpegX general discussionReplies: 11Last Post: 24th Aug 2011, 08:13 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 14:21 -
Question how to edit several minutes of avi at frame level
By jimdagys in forum EditingReplies: 9Last Post: 23rd Dec 2008, 19:26
