I was wondering what I should be setting my sound quality at in Tmpg. I have currently been using the default of 224 (or whatever it is) but was wondering if I should use 128 or 196 to save space for video. Will I notice the difference? Which should I use?
depends on your setup. on my mono tv i cannot tell the difference between 224 and 128.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
You'll notice the difference if slide below 128, 160 and higher would be a better choice.
Thanks for the reply. I just use the stereo speakers built into my TV so I should be fine with 160 or 192.
if your just watching via your tv then drop the audio bitrate to 128kb/s. you'll never notice the difference and you'll be able to up the video bitrate for a better video quality. i do this every time.
Recording High Quality Sound on PC
By evil nemesis in forum EditingReplies: 11Last Post: 25th Feb 2012, 14:36 -
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 20:27 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 22:15 -
sound quality
By ecos in forum Newbie / General discussionsReplies: 10Last Post: 1st Jul 2007, 17:34
