I installed ATI MultimediaCenter 8 and now I can't copy many VHS tapes. A message pops up saying they are protected. I knew that this was part of MMC 8 but figured someone would come up with a hack. Any Yet?
(p.s. I am only interested in backing up tapes that I own)
Revert to a previous version. Or buy a time-base corrector. Anyway, I'd have to say I wasn't happy with MMC 8 anyhow. I went back to 7.5.
Most likely it's not MMC8.1 but the drivers loaded. Ther is a patch for the drivers that helped with my WIN2000 drivers for an AiW 128 Pro. Should hopefully also work with newr cards / drivers.
go to
www.doom9.org
Look under "Download" "Support Utils" and expand to "show all support utils". Here is the ATIMacrovisonRemover. -
Thanks both of you. Luckily coppervids suggestion worked. I was aware of the macorovision patch but I thought I was dealing with something new since I never had my computer refuse to copy a tape before.
Thanks -
Ok im dumb here i did not know i could get around macovision. Im using mmc 7.5 & it does not work with macroV how do i make it work?
"Man who walk through airport turnstile backwards
going to Bangkok." -
oopps i ment mmc 7.7 not 7.5
It works the same way for ALL versions of MMC as not MMC prevents recording from Macrovision protected material but the Windows drivers. Just apply the same patch as recommended before.
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Copy inhibit signal prevents me from backing up my old VHS tapes
By ShaneJensen in forum Capturing and VCRReplies: 33Last Post: 28th Jun 2010, 20:39 -
Help Copying a protected DVD
By leahratcliffe in forum DVD RippingReplies: 3Last Post: 7th Sep 2008, 09:44 -
I have a ati 650 and need to capture some VHS tapes
By Onceler2 in forum Capturing and VCRReplies: 4Last Post: 14th Jul 2008, 07:00 -
Macrivision prevents copy from VHS to DVD recorder
By coody in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Oct 2007, 23:54
