Ok, I am using CCE and I am tryin to get the video file from the movie to author it which I can do the problem is when I add the DivX 5.03 movie into CCE, get all my settings right and then finally click encode I get an error message that says:
Can someone tell me how to fix this?Couldnt find approiate video codec for 'div3'
Justin
:agree: -
you don't have that codec.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I get the exact same error message. Also complains about 'div4' files as well. I know I have these codecs installed as Vdub and TMPGEnc handles them just fine. I was just wanting to compare their output with CCE output.
Any help would be appreciated. -
The only thing I can think of is that you frameserve the .AVI file through AviSynth. You got to have a CCE version which accepts AviSynth files though.
problem with Dr Divx & VirtualDub Mod
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:59 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 08:02 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 10:39 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 10:04
