Results 1 to 10 of 10
  1. if i use the overburn function does it have to be disc at once or is there anyway i can burn it track at once.
    Jan 2003
    Lighthouse Cove, Ontario
    to my knowledge it has to be dics at once
    but i wouldnt recommend using overburn as it can damage your drive, and make you buy a new one.
    it happened to me
    what would you rather do, spend $0.50 another blank cd to put the extra information on, or pay $60 for another burner?
    simple but concise,
    Syndrome
  3. DAO must be used but look at "CD Writers" to the left for overburning capability first.If you have a Cyberdrive,Lite-On or Asus don't worry they support overburning.
  4. Member Cornucopia's Avatar
    Slightly OT:
    Does anybody know if you can overburn a DVD-Video? My bets are NO, but I'd love to be proved wrong.
    Mar 2002
    United States of America
    Originally Posted by Cornucopia
    Slightly OT:
    Yes, you can overburn a DVD. There's a topic discussing this matter someone.
    Aug 2002
    Behind the wheel of a R34
    I dont think u can
  7. When you overburn, its not so easy to make a copy of it again and possible even not on an other writer or media !
  8. people are saying that overburning will damage the burner, but if the CD capacity is over 80 then overburning shouldn't be a problem and should not damage the burner right??
    Mar 2002
    Right on.
    Mar 2002
    Originally Posted by WeedVender
    I dont think u can
    Yes you can:
    https://www.videohelp.com/forum/viewtopic.php?t=149997&highlight=
    :P
