I need to make VCD's out of my captured material, and I want the highest possible quality. I captured to an uncompressed avi file 352x240 with virtualdub, and I used TMPGenc, VCD template and highest quality(very slow), and I wasn't quite satisfied with the results. Is there any way to get a better quality VCD. I don't care how long it takes!
you can make an xvcd or svcd.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
in tmpeg on settings you can reduce ghosting ..improve sound..sharpen edge..ect...just click on advanced tab
VCD is all CBR fixed, so there's not a lot of choices except for filter. Oh yeah, the highest precision doens't help any, just makes the encode longer, #2 is just fine.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 19:32 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 15:57 -
Highest Quality XVID to DVD
By Merkaba188 in forum Video ConversionReplies: 10Last Post: 1st Jan 2009, 21:58 -
Compressing with the highest quality
By guitarscn in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2008, 14:02 -
How do I capture Sky Tv at the highest possible quality?
By Gun in forum Capturing and VCRReplies: 0Last Post: 17th Sep 2007, 12:45
