i have had great success converting about 22 movies to svcd, but i have several movies that freeze up encoding at frame 15. all the movies have been downloaded from Kazaa. the ones i am having trouble with now are lion king and dinosaur. any suggestions?
Results 1 to 14 of 14
Go to the tools section on this site and download VirtualDub and use it to check for bad frames.
you'll need a version of virtualdub call "VirtualDub mp3 freeze". There's a guide on this fine site that will instruct you! Good luck!
Bravoxena -
ok thanks. now i haven't had to use virtudub yet, where can i find the guide to use it, and will this program fix the freezing problem so the movie can be converted?
i know that the previous post may seem dumb, but i just don't know where to look, please help
Here's the download link to VirtualDub MP3:Originally Posted by forgetech
http://www.digital-digest.net/downloads/files/virtualdub/vdub_mp3_freeze.zip
Hope That Helps!!!
:P
Here's a guide for taking out the bad frames in your file:Originally Posted by forgetech
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
Sure, I hope the results are successful!!!Originally Posted by forgetech
:P
after i search file for freezes, the guide says to open log, how do i do that?
after the search ended, a window opened up to log the freezes, i clicked the ok button, and now don't know how to get to the log ni order to delete the bad frames. -
Click on the My Computer icon on your desktop. When the new window pops up click on your C drive. When your C drive opens up look for a notepad that says badframes.log. Open it and you will find a list of your bad frames there.
The log file is at C:\ , the root directory. It's a text file that can be opened with notepad or any word processor.
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
took out the bad files and saved the new avi ok. but when i run it in tmpgenc to convert it, it goes super slow, like 22 hours to convert 60000 frames. did i do something wrong? normally it takes about 2 hours to do this.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
TMPGEnc Problem - navigating one frame at a time
By ereiamjh in forum Video ConversionReplies: 4Last Post: 28th Jul 2010, 09:55 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 12:57 -
TMPGEnc - bad frame problem
By psyklax in forum Video ConversionReplies: 5Last Post: 30th Jun 2007, 23:44
