    Mar 2003
    Asheville, NC
    I've downloaded several newsgroup files that state "VCD ready" thinking they're mpg files. Instead, they are .bin and .cue files. What exactly are they? Are they the product of writing an mpg to a CD when using a VCD Authoring tool? In otherwords, to turn these files into playable VCDs, what do I have to do? Thanks in advance!
  2. Member Conquest10's Avatar
    Chicago, IL
    they are like cd images.
    His name was MackemX
    Mar 2003
    Asheville, NC
    Makes sense, but what do I do with them? Copy them directly to the CD? Or do I have to "open" them using some VCD authoring tool?
  4. Member Conquest10's Avatar
    Chicago, IL
    using vcdeasy you can burn it to a cd in the tools section.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    CDRWin also burns cue/bin image files.
  6. Member spidey's Avatar
    Apr 2001
    U.S.A.
    or burn in Nero or Roxio
    close the wizard (in Nero), selct BURN IMAGE from under File, select the cue file
    make sure you have both the bin/cue's in tha same dir and named the same with the exception of the extension
    ie
    movie01.cue and movie01.bin
    movie02.cu and movie02.bin
    They are disc images of an already authored disc.
    You can extract the contents via IsoBuster, or use VCD Gear.
    Another excellant multiplatform disc image creator and burning utility is Alcohol 120 % - not bad to drink either
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
