I'm trying to use the Adobe Premier plug-in with Cinema Craft SP 2.5. When I try to export video it gives me an error 'Frame Rate 1/1 not allowed' I checked and the frame rate is set to 1 but it's ghosted so I can't change it. Does it have to do with the video I'm working with or do I have a setup problem? The video is in Microsoft DV and I've re-installed twice.
Thanks for any help.
I have the same probelm. I'm using Adobe Premier 6.0 and windows 2k. I have this problem on my AMD and Intell system. Can anyone help?
i read somewhere that when u export, the framerate selected when creating a new project must be evenly divisible by the framerate of the export. for example, if 30fps is selected as the framerate for the new project, then ur export must be 30fps or 15fps.
<font size=-1>[ This Message was edited by: hitechjunkie on 2001-09-14 14:07:37 ]</font>
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
