hi iv just got a goodmans 3600pkt dvd player and was wondering if there is a way to get it to play vcd . all i get when i load a vcd is 'bad disk' is there a way to get it to play them ? do i need a diferent brand of disk ? .........help !
sorted it myself heres how
Multi-Region hack :
Power on the player and Open the tray
Key in 8, 1, 3, 2, 8
Press Enter until you highlight 9 (Multi-Region)
VCD Hack:
Turn On the player and place a VCD on the open tray
Using the front panel press Close quickly followed by Menu and 5 on the remote
This should load and play the disc.
If the disc fails to play then press 0, 0, 0, 1 and the disc should then play
hope this info is of some use to others
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
LG DV 390H - unable to play VCD
By rach1234 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 31st Aug 2010, 08:25 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
ACCURIAN APD-3955 play VCD?
By UltraVCDDVD in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 12:48 -
goodmans gdvd301rp dvd recorder
By harris87 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Jan 2008, 13:35
