This way has been working for me so far. DVD Decrypter first. VIDEO_TS and main movie files. If everything comes out to be under the 4.36 GB size it's fine. Scene select from the menu takes me to the correct place ( I generally like to keep the menu just for the scene select and setup functions ). Now when the movie is over the DVD-r size I run it through DVD2ONE. This is where i run into problems. Scene select is now off and the way I fix it is that I run it back through IFOEdit. That's another 20-30 mins. Is there just a way to fix the pointers of whatever you call them that links it to the correct time of the chapter without having to run the whole thing through again. I guess I'm just looking to fix the IFO and that's it.
Also the way I do this usually produces a movie that plays first then if I choose to go to the menu I can do so from the remote. I asked about fixing this last week and nobody answered back. What can I do to make the menu start first when I put in the disc. I know it's probably an easy fix but I don't even know where to began.
I'd appreciate any help. Hope I was clear enough.
you need ifoupdate.
put it in adjusted cell mode, easy to use and sorts your problem out in seconds plus you will get your menu first.
thingimijig. -
thingimijig
It worked. Although it erased the link for the play button. Weird. That really helps out with time. I was alittle confused on the whole ORIGINAL file and AUTHORED file. I thought original would mean the this is the one that I want to copy to the other but it's the opposite. Guess I don't have the lingo down yet. Now I have to figure out how to make the menu's play first on my past work. Thanks again.
what colorspace to select in Lagarith ?
By codemaster in forum EditingReplies: 1Last Post: 1st Jan 2012, 09:44 -
VirtualDub - resyncing audio?
By Jonz in forum Newbie / General discussionsReplies: 7Last Post: 28th May 2011, 16:01 -
what to select in coreavc at deinterlacing
By digitalray in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2010, 20:58 -
Resyncing a recently bought DVD
By Worst.episode.ever in forum DVD RippingReplies: 3Last Post: 10th Mar 2010, 02:59 -
How to quickly select pictures?
By coody in forum EditingReplies: 5Last Post: 27th Nov 2008, 22:10
