Hi all.
I have been burning DVD+WR's without a problem, except I sometimes see, during very fast movement of a person, for example, small blocks of pixelazation around the person in the video if they do a very rapid movement, like, say, turn their head real fast.
I don't convert an avi to mpeg without a minimum of 4000 for the bitrate. I've got a conversion I did with a bitrate of 5500, and I still have the problem.
I am using the following:
Computer Hardware:
P4 2.2ghz
512 megs RAM
Xtera Geforce 4 Ti4600 128megs RAM with VIVO using S-Video
HP DVD 100i DVD Burner
Western Digital 120mb ATA100 7200 RPM Hard Drive
Computer Software:
Windows XP Home SP1
WDM Drivers that came with my Video Card
Virtual Dub, latest version, to caputre video
Tmpgenc, latest version mpeg2 ability, to convert video
Dazzle DVD Complete, to authorize DVD's
Stand alone DVD players for playback:
Pioneer DV-414
Pioneer DV-341
Regardless of kicking up the bitrate, I still sometimes get the pixelazation effect when there is a rapid movement.
Is this a bitrate issue, or is there something else that I need to do?
Thanks in advance.
You don't mention the condition of the AVI. Are you capturing at a high enough quality not to have the pixelation introduced at capture time?
Exactly. What type of input is your source material? It's possible the pixelation is in the source material itself (common on lower bitrate DivX/XviD). If your source is CAM, or a noisy analog capture (like VHS), then it could be simple bitrate shortage. If your source is cam, you should consider CVD resolutions, instead of full D1/CCIR-601. The reduction in size will make much more bitrate available to your video.
If your source is noisy, you should clean it first with a good temporal smoother, or 2-d filter, before compressing to MPEG. You should also use multi-pass VBR, as the additional passes will help with bitrate allocation on difficult (high motion) scenes.Impossible to see the future is. The Dark Side clouds everything...
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 15:37 -
Picture looks like a puzzle of 1000s of small blocks
By Twheels in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2009, 12:58 -
Small help with Mpeg Video Wizard. Thanks.
By seymoria in forum EditingReplies: 3Last Post: 6th Sep 2008, 21:07 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 15:50
