the commercial dvds have them ....can i add my own audio soundtrack as an optional feature length commentary like family discussing the videos?like i put the dvd in, menu comes up and a choice of main feature or scene selections or view movie with audio commentary(home made)? what stream does the audio has to be in specifics?
thanks
to dvd or to dvd
Of course its possible, you just need to use an authoring app that supports multiple soundtracks. AFAIK, the directors commentary tracks are a completley seperat audio stream from the main audio. Generally, you would take a copy of the main audio, set it to low volume level and dub your commentary over the top. The use this as a 2nd, selectable audio track. Like all DVD audio tracks its must be 48Khz, and PCM, AC3 or Mp2 format.
Unfortunatley I can't think of any consumer level authoring apps that support multiple selectable soundtracks. Proffessional level apps like Maestro do if you can 'afford'
them!
Use DVD Fab to capture audio commentary rather than straight film dialog
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 20th Aug 2011, 12:26 -
MPEG Streamclip:DVD is ripped with commentary audio stream
By camilla89 in forum DVD RippingReplies: 0Last Post: 29th Aug 2010, 10:43 -
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 04:44 -
how to add commentary over dvd audio?
By Denvers Dawgs in forum AudioReplies: 3Last Post: 24th Nov 2007, 00:58 -
Add a commentary track to A DVD
By R3bel in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 09:42
