I bought LG´s DVD Rom 16 X and Power DVD software to play my original DVDs on, but I got the following problem when I try to play them:
When I insert any DVD ( region 4 ) in LG, a message appears and say that my display card is not working properly; " when the tv out of my display card is enable " . My display card is a Ge Force 2 mx 400 excalibur and it´s perfectly compatible with it ( according to Power DVD site ). How can I disable the TV out function ??? On video properties appears 2 monitors...
Thanks a lot
Try this link.
I used these steps to turn on my TV Out for recording to VCR.
You might be able to use it to turn it off instead.
It does deal with GeForce2
http://www.comprousa.com/support/howto/recording.htm
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 04:48 -
Problems in different equipment with .mpeg1 in Power Point
By carlosarano in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 10:25 -
Power problems with Canadian Xbox 360 is Australia
By ryangarfield in forum Off topicReplies: 3Last Post: 15th Feb 2009, 04:04
