Sampo has just released a new DVD player, the DVE-631CF. As far as I know, this is the only set-top DVD player that has a compact flash memory card reader on the player. It can be used to view JPEG photos on your TV, and can also be used to play back MP3 files and MPEG1 video files. And all such files recorded to CD-R can also be played back with this player.
The player is almost exactly the same as the now-discontinued DVE-620, with the addition of the CF adapter (connected to the IDE cable that also connects the DVD loader to the processor board), and the change in firmware necessary to access the CF adapter and play back the other file formats.
Unfortunately, I have not found any way to disable MV or change regions with the 631CF firmware.
I have just begun an evaluation of this unit. Check out preliminary info at this link:
http://www.geocities.com/reversengineer_2000/sampo/631CF/631CFgallery.html
BTW, 620 firmware works on this player, but of course you loose access to the CF reader and no longer have the JPEG playback utility.
-Craig.
Results 1 to 1 of 1
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 7th Oct 2011, 23:01 -
Looking for a compact DVD player
By okyup in forum Newbie / General discussionsReplies: 11Last Post: 4th May 2011, 14:36 -
Can we record videos directly to compact flash in sony pd 177?
By vinnyjoseph in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Mar 2011, 11:13 -
Corrupted file from Canon 5D, from compact flash
By elmuz in forum Newbie / General discussionsReplies: 2Last Post: 28th Sep 2010, 05:25 -
Compact Flash Player - Problems with DivX video
By Mojo2000 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2007, 11:13
