  1. I'm trying to copy Goodfellas which is a double sided DVD but not sure how to go about it. I know how to copy a dual layer (single side) DVD to a DVD-R using DVD2ONE or IC7.
    Any help is appreciated !!!
    Dec 2002
    Texas USA
    Why? Double-sided discs are the best to copy. Each side is just a DVD5. Rip it and reburn to two discs. Discs don't take up much room, and are only a dollar or so.
    If you still want to waste all that time squeezing it to one disc, there are tricks for DVD2One. I've seen them in the forums recently, just this past month. Keep looking through the archives.
  3. I never ripped a double sided DVD to one DVD5. If it is single layer / double side, do what VOODOO_child said.
    But you can copy it 2 one DVD I guess. Just rip both sides and make new ifo's for it. Or use the user definied size for both sides in DVD2One. But like I said be4, I never did double side / single layer to DVD5 before. And I don't think DVD2One will give good quality, since it is like 9GIG too 4.7GB. Worth a try tho, but no good hope You could use CCE instead
  4. Ripping a double-sided to 2 DVD5 is easy, anyone can do that but i want to join the 2 sides together and run it thru IC7 or DVD2ONE but not sure what tools i need to do that
