Is it possible to put two dvds onto one dvd and compress them down using dvd2one so they'll fit, if so how do u add all files to one video_ts folder ????![]()
I am sure this has been answered before. Do a forum search and something should come up
tried that , and it comes up with nothing found ??? thats why i asked the question , do u know how ????
If you don't need a menu, then this is one way to make a 2 movie to 1 DVDR.
The DVD will start with the first movie. To play the second movie, use the stand-alone player menu to select the second title (display or goto button).
Use DVD2one to transcode the first movie to folder1 and the second movie to folder2. In folder2, delete the VIDEO_TS files then rename remaining files to VTS_02_X.XXX. Move all the files to folder1. Now you have a folder with 2 movies but you have to modify the VIDEO_TS.IFO file to recognise the second movie.
Load in VIDEO_TS.IFO file with IfoEdit.
Select VMG_VTS_ATRT and change the 'Number of Video Title Sets' to 2.
Select VMG_PTT-SRPT and change the 'Number of Title play Maps' to 2.
Refresh the page (choose VMGM_MAT then back to VMG_PTT_SRPT). Enter the following:
Title_2:Title playback type = 20
Number of angles = 1
Number of chapters = XX
Title set number (VTS#) = 2
Title set Title-number (VTS_TTN) = 1
Select VMG_VTS_ATRT and change the following:
VTS_2: Number of audio streems in Title (VTSTT_VOBS) = number of sound tracks
VTS_2: Number of sub-picture streams in Title (VTSTT_VOBS) = number of subtitles
Select the VMG Overview page (1st line at top of screen) and Specify the audio tracks and subtitles if any.
Click the 'Save' button then 'Get VTS sectors' button.
Hopes this helps.
Chas
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
DVDs burned in Samsung DVD Writer only possible to watch in some DVD Player
By jorgepe in forum DVD & Blu-ray WritersReplies: 9Last Post: 4th Jan 2008, 04:15 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
