i'm new to this game, is wmv the same as asf?
bruceplugger,
Short answer: Yes
Long Answer: ASF is the old file extension for Microsofts Proprietary (Did I spell that right?) format. WMV is their new name basically short for Windows Media Video. But they both use the same file format, conspiracy I think so. Hope This Helps.
-Epi -
thanx for that, i have a wmv file that i'm trying to fix with virtudub 1.3, but am confused.
the file is corrupt and virtudub wont handle it, so can i fix it with VD. i've looked under the different headings but cant find any command to fix corrupt file.
any ideas or maybe other programmes that can handle wmv files, free of course. thanx -
Look for a program called ASFTools, that should help solve your problem.
-Epi
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused with Encoding
By skorpinok in forum Video ConversionReplies: 3Last Post: 29th Aug 2010, 10:40 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 08:36 -
Ire, still confused.
By aebbeka in forum Capturing and VCRReplies: 15Last Post: 25th Mar 2008, 05:25 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 08:14
