need a Capture Card transfer vhs tape from vcr to pc.and the best format so can burn it on to dvd.
If you're in the states then I suggest you just go to CompUSA and buy the program called "AVerDVD EZMaker" which comes with the software you need (NeoDVD), and an AVer PCI capture card. This sells for I believe $40 and is all you will need to do quality captures from VHS or other sources plus the software to edit/author/add menus/encode and burn to DVD+/-R. The format to capture is of course mpeg2. You may also just order this online at www.compusa.com .
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
