  1. hi.. i was wondering if anyone knew how to cut it in any freeware/shareware program? i tried in tmpg but it keeps coming out green when i stop it and vcdcutter's trial only lets me do a minute i can't find the setup for ifilmedit anywhere.. any help would be appreciated
  2. bbMPEG, the best there is. But you need to demux your program stream first, with TMPG, if necessary.
  3. alternatively you could try nanocosmos mpeg cutter by Hauppage on their website. It does mpeg 1 and 2 and as far as I know you don't need to have any hauppage products installed. I used it to cut some mpegs which were losing audio synch when I tried the same procedure with tmpeg's mpeg tools feature. you can find it on this page
    http://www.hauppauge.com/html/sw_pvr_250.htm
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    that nanacosmos software screwed up two of my workstations..
    Anyone else use it successfully?
