I have a Studio DV plus card. I have some high quality video clips that l have captured with my Sony digital camera and have successfully captured it into my PC.
I would like to edit this clips and a) burn them to CDs.
To maintain the best quality, i have been told NOT to use Studio Plus to encode the clips.
Do l just use Studio DV plus to edit and save it as an AVI file and then to encode with TMPEG? (to main the best results)?
Thanks in advance
Yes, that is what I learned to be the best approach. I learned this from this web-site, from Pinnacle web-forums and my own experience.
Good luck -
Hope some of the following infos help:
1) do not encode to MPEG with Studio DV due to horrible quality ( I know quality is very subjecttive but everyone seems to agree here)
2) save to AVI : limited to 4GB file size (18 min of video). This even on Windows 2000 using NTFS. This limitation is NOT due to the file system but due to some kind of bug in Studio DV software: it hangs at the 4GB limit.
3) save to AVI: take forever to create AVI (many x movie time). I normally save video back to the DV camcorder, then recapture to AVI again from the new tape (2x + rewind time). This way, it is faster and it has no 4GB limit if you are using NTFS file system. A bonus is you have a highest quality digital archive of your video work.
<font size=-1>[ This Message was edited by: ktnwin on 2001-09-13 18:32:44 ]</font>
Editing in Pinnacle Ultimate
By Ronan Carley in forum EditingReplies: 1Last Post: 30th Jan 2012, 01:11 -
Audio sync while editing in Pinnacle
By p_uriel in forum EditingReplies: 5Last Post: 13th Jan 2011, 14:13 -
How to convert .SDV files to something WMM recognizes
By Carppacio in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2010, 20:21 -
Slight EMERGENCY! Please help with editing .SDV files!
By Carppacio in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2010, 18:18 -
looking for the region free code for a toshiba combo SDV 398
By julax in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2010, 01:32
