I know DVDXCopy doesn't do it? How about DVD2ONE or DVDbot?
Try DVDdecripter. Use ISO read to make image, then use ISO write to burn image. It should work.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
it can be easier....just use your dvd burning program and do dvd copy...i use nero...works everytime
I think dvd decrypter is the best way, pretty damn cut and dry READ---WRITE ISO
Thanks alot,
dreadogg -
I had some trouble making an image first and found the easiest way is to copy the 4.3gb VIDEO_TS folder (and empty AUDIO_TS folder if you need it) to you hard drive and then burn as normal.
Copying from the dvd to the hdd takes me about fifteen minutes, far quicker than creating an image first I guess.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
How to copy back videos uploaded to youtube?
By come_mon in forum Video Streaming DownloadingReplies: 7Last Post: 16th Mar 2009, 16:47 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Troubles Make Back or copy
By thebirdf in forum DVD RippingReplies: 1Last Post: 23rd Jan 2008, 02:53 -
Does DivXToDVD's "back-up" function copy or re-encode or both?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2007, 18:00
